Top floor radiators hot...2nd floor radiator cold.
LI_CJ
Member Posts: 11
I just had my boiler replaced with a nice Peerless unit. I have a few radiators where are notoriously tough to bleed, and I think a little bit of air re-entered the system during the boiler replacement.
I successfully bled my third floor rads, but I have one on the 2nd floor in the bathroom that is cold. I have water coming out of the bleeder (vs air), so I'm thinking there is an air pocket trapped. The feed pipe to the radiator is warm.
Should I just run water out of the bleeder until I find the remaining air? I haven't attempted to bleed more than a quart or so at one time...so maybe I need to be more aggressive and run a few gallons through.
Any other suggestions?
Or you may need to do a good high pressure purge again.
If there is an airlock or bubble in the piping, it may be hard to bleed that out at a radiator.
Usually there is a means to isolate and purge the various zones or loops in the boiler room. Shut off valves and purge cocks of some sort.
Does the system have a good quality air purger back at the boiler? that will take care of any air that circulates after the initial purge id performed.Bob "hot rod" Rohr
Living the hydronic dream0 -
I'm good now. Revisited and the air worked its way through. One more purge and now I'm hot!
Thanks.0
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
