BG100 -> taco 007
RichC901
RichC901 Member Posts: 9
edited December 2016 in THE MAIN WALL
I’m going to replace a leaking (water) BG 100 with a taco 007 this weekend. I think it should be easy work – there are cutoffs above and below pump and the bolts look to be in good shape. My system is natgas hot water system, 3 zones, and mix of baseboards and radiators over 3 floors.
My question is do I need to bleed the system after I do the pump change? I don’t see an automatic air purger anywhere near my boiler. It’s possible I missed it or it’s on one of my radiators, but I don’t think I have one.
If I should bleed, do you recommend bleeding at the valve near the pump or at the baseboards/radiators?
Also, any gotchas you’ve encountered when swapping out pumps?
Thanks!
    hot_rod Member Posts: 25,668
    Make the swap without losing pressure or much water and you should be fine.
    I like to install the new pump and leave the bolts at the discharge end a bit loose. Open the lower valve slightly to fill the pump with water, burp the air, so it starts up. Tighten everything, re-pressurize to correct fill pressure.
    Consider the electronic version circulators.
    STEVEusaPA
  • RichC901
    @hot rod, such a simple and brilliant trick! Leave the bolts loose and burp the air out. Thanks man.
    What brand electronic circulator do you recommend? My pumps are on return side, one for each zone. So I don't think I need a variable speed pump.
    How many pumps? I was think more for energy consumption than the variable speed function.
    In some areas there is a rebate program for installing ECM circs.
    All the brands offer quality products, what color do you prefer :)
    Plenty of promotions at counters this time of year.
    Ideally you would know the required gpm and head for each zone to select a replacement.
    If you want to stay with that brand, the B&G Vario has a wide adjustment range, nice for zone pumps. A good replacement for those series 100's
  • RichC901
    I did the swap out this weekend and it was easy. Had a little air above the top bolts, but that seems to have moved somewhere else in the system.
    Thanks for the education on ECM circs hot rod. Actually looking forward to my boiler dying, so I can modernize the whole thing. Until then, I'll keep slapping on the band aids.
  • JohnNY
    JohnNY Member Posts: 3,326
    The widely overused B&G 100 most closely matches the pump curve of the Taco 0010. Here is the nice curve chart I marked up for the binders my guys carry in their trucks:
    Consulting & Troubleshooting
    Heating in NYC or NJ.
    Classes
    CanuckerSWEI
  • Solid_Fuel_Man
    I have honestly wondered where Taco gets their numbers from. The curves seem to not have any correlation with the curves. Although the lower 00 numbers have smaller curves.
    Taylor
    Taylor
    Better yet, no curve at all.
    PAB get you close on a fixed speed circulator.
    ∆P circs. properly applied gets you straight-lining.
    SWEI
