Expansion tank brackets
![njtommy](https://secure.gravatar.com/avatar/6334d0afb9b3770ae12f1ce290374fd5/?default=https%3A%2F%2Fvanillicon.com%2F36b17d29f987d90e6be22f02d48f6903_200.png&rating=g&size=200)
njtommy
Member Posts: 1,105
Hey guys I'm looking for expansion tank brackets like this one here. Any idea where to find them?
Thanks for the help.
http://www.regulusromtherm.ro/ro/expansion-vessel-mounting-arm-complete
The giant hose clamp/bracket setup ng?0
@njtommy why not try a local suppky house....plumbing supplies by me stock both types....i know johnstone supply has them since your in nj.....i like the bracket type better....the type in your pic above is more expensive and requires plugs, air vents etc too which do not come with the setup....i would just get a bracket type like the hydroclaw or the hose clamp type.ASM Mechanical Company
Located in Staten Island NY
347-692-4777
ASMMECHANICALCORP@GMAIL.COM
ASMHVACNYC.COM
https://heatinghelp.com/find-a-contractor/detail/asm-mechanical-company0 -
I have seen those at supply counters across the US. Ferguson, Denver was on place.
Rathe Associates on Long Island carries this Calefactio brand.
Living the hydronic dream0 -
I always used a 10" Unistrut pipe clamp (galvanized) and 1-5/8" strut. Too much torque on two screws for me with those wall claws. I like spanning at least two studs.
METhere was an error rendering this rich post.
Are you looking for just one, or an ongoing source? I have some samples of this Caleffi brass version. It came in a little $$ so we don't bring them over.
I adjusted the metric connections.
Fill valve screws in the bottom, has a check valve for the expansion tank for removal and service. You are welcomed to one.
The HydroClaw that the Perry boys manufac
@hot rod
I definitely need 1 for now on a job that I need to go back on and finish, but if they aren't available here don't worry about it. I would like to try and get my main supplier to get them for me. As I told them with the Taco VR and VT pumps if people know or see you stock them you will sell the pumps.0 -
I realize this thread is a few months old but if you're interested in the HydroClaw I would love to talk to the supply house in your area and see if they would like to carry our bracket.
Jeff
Storm King Enterprises0 -
Thanks Jeff I've actually ordered a couple of the hydro claws from supplyhouse.com. Just so I have them when needed. You guys make a nice product thanks.0
I'm bringing this thread back to life. Any new favorites out there? It seems Axiom makes the most comprehensive bracket assembly but it's not available for several weeks.Contact John "JohnNY" Cataneo, NYC Master Plumber, Lic 1784
Consulting & Troubleshooting
Heating in NYC or NJ.
Classes0 -
This one is pretty slick.
https://www.supplyhouse.com/Flamco-97975-Flexconsole-1-2-x-1-2-NPT-Steel-Red"If you can't explain it simply, you don't understand it well enough"
Albert Einstein1 -
What do you think of this bracket I designed it to be used for potable or hydronic, its stainless.
1/2 & 3/4 tank connections, 1/4 for rear mount pressure gauge, fill valve connections.Bob "hot rod" Rohr
Living the hydronic dream1 -
Sweet! I'll take one.hot_rod said:What do you think of this bracket I designed it to be used for potable or hydronic, its stainless.
Classes0 -
I used the Flamco AND the HydroClaw on my own system just because.
Steve Minnich0 -
How about support for the ASME exp tank? The ones that look like a small "Fat Boy". Looks to be the physical size of a ST-12.
I have one about 12' off floor, can't get to it unless I haul the ladder in to redo some other plumbing.
Brilliant installation....completely engineered in 1997.
Installed by company more than 100 miles away so you know they were "pros".
You have to shut the entire K-12 school off to remove it.
No check valve anywhere.....wasn't needed then.
But will be necessary with piping corrections.
1 -
I suppose it depends on the installation, but I have yet to find anything better than the HydroClaw for what I do. They're darn spendy, but then again so are the arms and the arms take WAYYYY more labor.0
- 86.6K THE MAIN WALL
- 54 Biomass
- 100 Chimneys & Flues
- 5.6K Gas Heating
- 101 Geothermal
- 158 Indoor-Air Quality
- 3.5K Oil Heating
- 66 Pipe Deterioration
- 934 Plumbing
- 6.2K Radiant Heating
- 384 Solar
- 15.2K Strictly Steam
- 43 Industry Classes
- 48 Job Opportunities
