cutting steel pipe
Paul S_3
Member Posts: 1,261
What is the best and fastest way to cut steel pipe 2.5 in and above.... i have always cut pipe using my manual steel pipe cutter in the pic below....but it takes too long about 5 minutes a cut and its tiring.....Any recommendations?
ASM Mechanical Company
Located in Staten Island NY
347-692-4777
ASMMECHANICALCORP@GMAIL.COM
ASMHVACNYC.COM
347-692-4777
ASMHVACNYC.COM
I recall others mentioning a portable band saw being good for it.Single pipe quasi-vapor system. Typical operating pressure 0.14 - 0.43 oz. EcoSteam ES-20 Advanced Control for Residential Steam boilers. Rectorseal Steamaster water treatment0
band saw or a chop saw. I've used both with no issues. Chop saw cut needs a little more cleanup on the cut end. Band saw is a bit cleaner but still needs a bit.0
Here is a piece of 4" schedule 80 I just cut, just under two minutes. I'd guess less that a minute for 2.5 schedule 40.
It does throw some sparks and you need a solid 20A circuit. You may need a fire permit to use it in your area, like a torch or welder?
No cleanup on the cut if you are threading, inside is burr free also as long as you don't force the cut or have a dull blade.
Living the hydronic dream0 -
thanks guys much appreciatedASM Mechanical Company
347-692-4777
ASMHVACNYC.COM
https://heatinghelp.com/find-a-contractor/detail/asm-mechanical-company0 -
Portaband. You can get a square cut with practice, & it's easier to ream, I feel, that trying to take off the lip that a pipe cutter leaves on.
The Sparkys around here are using the little battery powered circular saws with some kind of carbide blade to cut EMT, but I'm not sure how well that would scale to larger/heavier pipe.
1 -
@hot rod what kind of a blade do you have on there? Looks like a toothed carbide?0
Yes it is a 14" Diablo blade, this is the saw.http://www.dewalt.com/products/power-tools/saws/chop-saws-and-multi-cutter-saws/14-355mm-multicutter-saw/dw872
This is the second blade, it does have more and different types of carbide that the one that came with it. A local saw shop sold me the blade when I told him what I wanted to cut.Bob "hot rod" Rohr
if its rip out i use a sawzall just follow the cut and molve a bit to use different parts of the blade portabands good but full size a bit heavy and harder to control or get pinched chop saw is all i use on no hub now since my snapper got robbed, if its cast rip out ill use a carborundum blade in a circle saw or angle grinder depending size and location1
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 850 Plumbing
- 5.8K Radiant Heating
- 372 Solar
- 14.5K Strictly Steam
- 58 Water Quality
- 39 Industry Classes
- 15 Recall Announcements
