Pump to empty
Since old WHs don't like to drain, what kind of pump do you boys use to help them along? Thanks
  • STEVEusaPA
    just that standard cheapo plug in that has hose connections on each side. Probably bought it from HD years ok
  • SWEI
    SWEI Member Posts: 7,356
    Valve off the cold line, air compressor coupled to the hot line.
    Did you pull the drain valve?
  • kcopp
    kcopp Member Posts: 4,435
    edited August 2016
    Liberty 331. pump.
    hot_rod Member Posts: 22,218
    air compressor was my favorite method. pump to 100 psi and watch them drain!
    Agree, remove the bottom drain and put a nipple or hose adapter on. those round plastic type of drains plug quickly, even the brass compression style.
  • John Mills_5
    John Mills_5 Member Posts: 952
    Thanks guys!
