Emerson Comfort Alert
ratio
Member Posts: 3,645
Does anyone know, precisely, what causes a " short cycling" lockout, red on solid, yaller flashing 3? I found docs on its big brother the PerformanceAlert which calls out that alert as 240 starts with normal stops in a 24h period.
I assumed that the problem actually was short cycling & so I added a five minute delay on break timer. That seemed to help, but the unit (dual circuit 10 ton condenser) was locked out again this afternoon.
Information on this unit is scarce, & at least one guy I've talked to about it said he usually removes them if they keep tripping out.
- 85.7K THE MAIN WALL
- 49 Biomass
- 73 Chimneys & Flues
- 92 Geothermal
- 150 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 850 Plumbing
- 5.8K Radiant Heating
- 372 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 39 Industry Classes
- 15 Recall Announcements
