propress
lchmb
Member Posts: 2,997
anyone run into any failures with the tools? Namely the jaws failing?
I've had Ridgid for 10 years o think, I may have had to replace one jaw but my memory is slipping. What type of problem are you having? I do recall sending one of out small batery units in for service, and I can't remember why either.0
had a jaw explode today during a press...Using it on 2" fitting for black iron gas. Seem to also be having trouble with it creating a knife edge on the press. We heard that happens after a lot of use but this one's a week old...0
Ahh maybe a dud? Our mega jaws have been fine0
Never had a problem like that, I'm gonna guess you had a dud.0
hope it's the last dud we have...rather painful and we just purchased 3 kits...0
I gotta say I am not at all comfortable with the gas press stuff....Black pipe that we so nicely purchase from overseas is not impressive....Never put a micrometer on it but, I would be interested to see if the outside diameter is as standard as they say....now there are fittings for steam and fittings for gas....outside reaming is as important as inside reaming, you know how that goes...I am sure it's a fine product, but just not necessary....jmo...@johnny88 yup don't give away that 300jonny88 said:Scary.I will keep my Ridgid 300 for gas work thank you.
1 -
@ja I was doing a install in a training centre for vets and kids coming out of rehab etc. Viega equipment.In the house we had 4 different categories of heat.The viega rep was there to show us the PP on gas for hooking up boiler.Not alone is it way over priced but parts were hard to get..It all went in fine but I promised never to use it again.I like to be able to feel the pipe make up.Maybe it is not keeping up with the times but I will def. be threading for the forseable future.
1 -
I can appreciate a nice threaded piping job. But in some case's I do like the idea of the propress. We were using this on a school roof, and personally I think the viega fittings will be stonger in the long run than a threaded pipe. Do I think the price is crazy on this, definately. But we needed this job done fast and 2 hours to run 175 ft of pipe is pretty impressive...til it broke anyway..1
Hopefully they will cover this under warranty.
I do know of one incident where they were using Megapress on gas on the outside of a building in Newington NH. A huge slab of ice took out the gas meter and supply off the gas entrance. The meter smashed but the press fittings still remained intact.0
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 848 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
