i have an old Hoffman number 15 vacuum valve leaking steam
PaulStraface_2
Member Posts: 5
This is probably mounted on a dry (overhead) return near a Differential Loop, on a Hoffman Vapor system. If there's steam in that dry return, one or more traps need to be repaired.
For a replacement, I'd use one or more Gorton #2 vents.All Steamed Up, Inc.
Consulting1 -
thank you for the advise. yes it is on the dry return and it is not a vacuum system any more has a vapor stat running at 8 oz. We are replacing 7 bad traps as well. There was coal at one point because there was an old coal shoot in the basement but gas now.0
Don't forget the "crossover" traps at the ends of the steam mains.All Steamed Up, Inc.
Consulting0
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 850 Plumbing
- 5.8K Radiant Heating
- 372 Solar
- 14.5K Strictly Steam
- 58 Water Quality
- 39 Industry Classes
- 15 Recall Announcements
