Oil fired steam boiler has massive leak
Thank You
Tim
I would first locate the leak to be sure it's the boiler and not some other line leading to it. If it's the boiler, it's toast, unfortunately. That's a lot of water to be coming out the bottom. The usual place for leaks is at the water line.
If it needs replacing, I go ahead with a gas line and install a wet-based power boiler with a gas conversion burner. There are many available in different sizes and are no more expensive than an atmospheric, but are more efficient to run. However, you must first measure the EDR of your radiators to size the boiler correctly. Do not go off the old boiler as it may not be right. Also, be sure NOT to change the water line with a new boiler as it can lead to many problems such as loud hammering.
I'm just a HO like yourself, but recently went through a similar scenario. The folks here helped me get a super install, which would NOT have been the case otherwise.
Further pics of the boiler and rads would help.
P.S, I might also repost to the Stricly Steam section for a better response.Two-pipe Trane vaporvacuum system; 1466 edr
Twinned, staged Slantfin TR50s piped into 4" header with Riello G400 burners; 240K lead, 200K lag Btus. Controlled by Taco Relay and Honeywell RTH6580WF0 -
Vaporvac,vaporvac said:I would first locate the leak to be sure it's the boiler and not some other line leading to it. If it's the boiler, it's toast, unfortunately. That's a lot of water to be coming out the bottom. The usual place for leaks is at the water line.
Thank you for the response, thankfully this happened during the summer so I have time. I spoke to a heating company and they said it would be "alot" for a new boiler (switching to baseboard) but I am not buying it. Its only a 1200 Sq ft house, and I am positive the radiators still work perfectly fine (they did all last winter) I will inspect the boiler thoroughly and provide more pics of everything. Its a single floor, one pipe system as well (no leaks on steam pipes at all). My biggest challenge is finding a HVAC person/company I can trust. I got burned when we first bought the house and called for a tune up. I will repost to the section you mentioned. I am curious what you paid for your install but I know the site prohibits discussing pricing. Is there an option for private chat?
Thank You
Tim0 -
Have you tried the find a contractor link on this site? Go out to a big radius many steam men will travel. Also if you post your location we may know somebody close to you. If neither of those options pan out and you are looking on your own ask them for pictures of some of their installs and post them here. We can tell very quickly if you have a good steam contractor or not. If they walk in talking about a baseboard conversion just show them the door immediately.
https://heatinghelp.com/find-a-contractor/0 -
There's no reason at all to switch to baseboard. Stay with the steam, but ditch the heating company that said anything about switching to baseboard. Find someone who can do steam -- as KC said unless you are really out in the boonies somewhere there are folks on this board who will travel.
Where are you located?Br. Jamie, osb
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 848 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
