installing a stop and waste valve
Sorry I didn't see this sooner... The bleed on an s&w (assuming here that you are referring to the standard in-line globe valve type) should be oriented down to drain. The runs should be horizontal -- vertical will leave a pocket of water, which can freeze.
It is essential that it be installed right way round, so that when it is off you can open the waste and it will drain the line! That's what it's for, after all...Br. Jamie, osb
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
