dielectric Unions
Deano
Member Posts: 1
Are dielectric needed or required on hot water heating systems?
NO, but you have to having a grounding strap from what I hear, thats what the dio do from my understanding0
Not needed in a closed system (and adding one to an open system won't help anyway.)0
Here is what dielectric unions often do. This was probably a domestic water system.Bob "hot rod" Rohr
Living the hydronic dream0 -
Depends. On conditions and what sort of dielectric is used. Look at the opposite point of view. Those fancy copper shower bath fixtures which include overflow and drain.Works of beauty.But an evil plumber will substitute one little ferrous piece somewhere.To create work for his grandson's generation? Drain piping is dry 99% of the time. But that little ferrous piece will plug up the copper over the decades.
So how do we join dissimilar metals? Is that pipe in HotRod's picture galvanized on inside? How hot was the water? And so on.
Maybe the crud is in spite of dielectric? Depends.0 -
On a closed loop piping system there is no need to have any separation between metals. It becomes an O2 free system after a few days and no corrosion is possible without O2.jumper said:Depends. On conditions and what sort of dielectric is used. Look at the opposite point of view. Those fancy copper shower bath fixtures which include overflow and drain.Works of beauty.But an evil plumber will substitute one little ferrous piece somewhere.To create work for his grandson's generation? Drain piping is dry 99% of the time. But that little ferrous piece will plug up the copper over the decades.
Unless of course you connect non-barrier tubing into the system
A brass nipple is a good isolation between copper and steel, like the water heater port.Bob "hot rod" Rohr
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 848 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
