L7224C1004 & Boiler temp do not match
Benjamin
Member Posts: 2
I have a New Yorker boiler with a tankless coil. Our domestic hot water supply has been subpar. I noticed the HL was 170 and LL was 140, so I turned them up to 190 to 170. That fixed the domestic hotter issue, but i noticed the boiler T&P gauge read 220 when it shut off, and the aquastat read 190. Need some help here please.
I have never had an issue with those aquastats. It may be more residual heat after the burner has run that is driving up the temp. Do you have a mixing valve? Your problem is more likely there if you do. I would set it 160/180 for now, and have the control checked and compare it to what the gauge reads.0
A tridicator is far from a scientific instrument!To learn more about this professional, click here to visit their ad in Find A Contractor.2
For sure Robert. I like my infrared to throw an objective third party into the mix, and usually side with it0
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
