15 Year Old Pex & Brass
BigRob
Member Posts: 322
I needed to simplify some piping and removed some PEX installed about 15 years ago. I was pretty amazed how pliable the 1" pipe still is. I would say this pipe was abused. There was a bucket of iron oxide in this piping system for years. I would say at least 5+. Also, the water temps were very high- 150's to 180's. I was really concerned about our piping and brass fitting condition, now, not so much. I'm a pex believer now. I Just hope no rodents show up.
I couldn't find pex A or B for a small exposed new section, so tried some pex C. The brand I found was really hard to bend compared to the old stuff and doesn't hold its shape nearly as well. It was about 65F outside. Not sure If this is a function of age or what.0
When you say "exposed" I hope you don't mean to any UV rays. Sunlight will kill PEX, A,B or CBigRob said:I couldn't find pex A or B for a small exposed new section, so tried some pex C. The brand I found was really hard to bend compared to the old stuff and doesn't hold its shape nearly as well. It was about 65F outside. Not sure If this is a function of age or what.
Thanks for checking. I meant it was visible inside the building.0
I have found PEX-A to be the easiest to work with as well as the most durable. As with any PEX though, the warmer it is, the more pliable it is.0
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 849 Plumbing
- 5.8K Radiant Heating
- 372 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 39 Industry Classes
- 15 Recall Announcements
