keeping cool...
vaporvac
Member Posts: 1,520
Perhaps this is the solution to combining steam with cooling... no ductwork!
vhttp://www.voanews.com/content/high-tech-material-cools-buildings-sending-heat-into-space/2536347.html
Two-pipe Trane vaporvacuum system; 1466 edr
Twinned, staged Slantfin TR50s piped into 4" header with Riello G400 burners; 240K lead, 200K lag Btus. Controlled by Taco Relay and Honeywell RTH6580WF
I think that we will have more visits from people from other worlds with complaints. if this done. We are just throwing our unwanted energy out into space, and maybe overheating them!
I'll be interested to see how this turns out.--NBC0 -
"" The panels, which are cool to the touch even in the sun, can reduce indoor temperatures to nearly 5 degrees Celsius below the temperature outside. ""
So, as I see it, once you've spent MILLIIONS on this scheme, if it 100 degrees outside, it will cool the building to 95 degrees inside? Convert it to Celsius. Lets call it 90 degrees inside.
The gals will be complaining.0
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
