HW S8610U ignitor control
Techman
Member Posts: 2,144
in Gas Heating
In the green LED Status Code section , what does 9 blinks mean? Its not in the chart.
I assume this is on the new S8610U - 3009 (black case)? Is it the modified version which has just one diagnostic light? The modified version has test points for taking microamps. I do not have my diagnostic codes handy they are at the training center. I will check tomorrow and get back to you.0
Tim, yes it is a black case,w/ one light.The fault codes go from 1-8. Thank You.0
You are correct there is only 8 flash codes. What is it doing as far as operating? You might try contacting Honeywell for assistance.0
Hi Timmy, I called HW and they said that 9 blinks is a "everything is normal" indicator. Its an indicator of the flame current from the pilot flame. Tks .0
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 848 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
