Low flow air solar walls
G Twitchell
Member Posts: 10
in Solar
I have not read any posts about these Conservall (brand name) type of solar collectors.
I installed these (4 - 4'X16') units about 7 years ago, they each have a 8" duct with a active damper and duct fan that is controlled by a demand stat and a micro processor at the top of each panel that says that the panel is warm/hot enough to come on.
I was concerned about tight house problem with my ICF construction and need make up fresh air and this works great.
I like this concept and it works for me.
George Twitchell
George Twitchell
good old days
Saw many installations in Canada on industrial buildings in nineteen seventies. Difference between comfy and chilly is only a few degrees.0 -
SRCC is rating
and certifying performance of air (transpired) collectors now. Some some actual performance and durability data is available. Looks like your brand is one of the listed.
http://www.solar-rating.org/ratings/transpired_10001759_20140516.pdfBob "hot rod" Rohr
Living the hydronic dream0
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 848 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
