Cast Iron boiler trouble
TERRY1
Member Posts: 9
What would be the cause of a hot water boiler short cycling with a high pitch "whistling" noise and shutting down immediately, within 5 seconds?
Whistler
It sounds like 2 issues...first no water flow / bad circulator...and second more dangerous no or low water in the boiler. Shut off asap! Especially if you do not have a properly installed low water cut off.LANGAN'S PLUMBING & HEATING LLC
Considerate People, Considerate Service, Consider It Done!
732-751-1560
email: langansph@yahoo.com
www.langansplumbing.com0 -
where is the noise coming from
what kind of boiler- gas oil brand model?????0
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
