Residential Steam Trap Testing, Tempil Sticks
Ed. W.
Member Posts: 26
What Temperature, Tempil sticks should I use to test the functioning of a residential steam traps (running at .5oz), for the temperatures before and after the trap?
Thanks,
Ed. W.
Thanks,
Ed. W.
Well...
I use an infrared thermometer.
However, the outlet of the trap -- a few inches (if you can get that far) from the trap itself should not go over somewhere around 210. Better maybe 205. The inlet can go right up to steam temperature -- 212 -- depending on the radiator and if there are any throttling valves or orifices present.Br. Jamie, osb
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
