To get email notification when someone adds to a thread you're following, click on the star in the thread's header and it will turn yellow; click again to turn it off. To edit your profile, click on the gear.
The Wall has a powerful search engine that will go all the way back to 2002. Use "quotation marks" around multiple-word searches. RIGHT-CLICK on the results and choose Open Link In New Window so you'll be able to get back to your results. Happy searching!
In fairness to all, we don't discuss pricing on the Wall. Thanks for your cooperation.
heater/thermostat issue?
gookgook Member Posts: 1
When I turn the thermostat on the heater comes on, works fine until it reaches the temp that it's set at and then turns off normally, just like it should. But it will not turn on again when the house temp falls below the temp set on the thermostat. The only way to get it turn on again is to turn the thermostat off and back on and it works "properly" again until it heats the house to the right temperature, then turns off "properly", but never comes on again. The thermostat is a programmable type thermostat and is 13 years old. Is it the thermostat or something in the furnace? It is a natural gas, hot air heater.
Thanks.
  • IronmanIronman Member Posts: 3,114
    The Issue...
    Requires a meter and someone with the knowledge of how to use it. It could be in the furnace and it's locking out or it could be the thermostat or wiring. You need a tech on site.
    Bob Boan
Welcome
It looks like you're new here. If you want to get involved, click one of these buttons!
