radators how much tilt?
Hollis
Member Posts: 105
I understand that one pipe radiators should be tilted back toward the pipe but how much, most of the ones in one house are very slightly tipped back. Is there a rule of thumb? On a reg.level,..a quarter, a half a bubble?Or just if you don't hear gurgling noises in that radiator and it heats well?
Tilt
Just a little bit of slope is necessary to get the condensate to flow back to the valve.
Don't tilt too much as the condensate should gently flow back underneath the steam.--NBC0
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 848 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
