How much water?
Dsisson
Member Posts: 92
One pipe steam system. 1year old burnham boiler. Water line drops approx 1" every 2 weeks. 3 of my radiator valves have slight leaks.
Is this a normal ammt of water to add? Obviously I need to fix the valves.
It's not that evil...
but it is more than it should be if the system were tight. I wouldn't be that surprised, though, if fixing the leaks on the valves made a big difference. Surprising how much water a "slight" leak really is!Br. Jamie, osb
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
