Turbomax Storage - LIFO or Symmteric?
WeatherizationNYC
Member Posts: 1
<span style="font-size:12pt">Good morning,</span>
<span style="font-size:12pt"> </span>
<span style="font-size:12pt">I’m looking at two Turbomax storage tanks which were to be piped in Last-In-First-Out order, according to spec. The contractor piped them symmetrically instead. </span>
<span style="font-size:12pt">Can anyone tell me whether the symmetric piping arrangement will cause any problems, impact the lifetime, etc? Should I have him re-pipe it?</span>
<span style="font-size:12pt">Thanks in advance.</span>
Not a problem
I think a simple symmetric header will work just fine. The objective is even flow. Both piping strategies will accomplish that.
Albert Einstein0
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 848 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
