Help with thermostat
Andrew boiler
Member Posts: 44
The temp for the thermostat. Is saying its 72 and it is set at 68 is due to the room temp I thought when it's set at 68 it will stay at 68 can any one tell me what I am doing worn?
Too many posts..
Not enough information.
One post per subject."If you can't explain it simply, you don't understand it well enough"
Albert Einstein0
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
