Thermostat help
Andrew boiler
Hi I just got power back 1 this morning and my thermostat says it's 69 I have it set at 68 it's very cold I don't want it to turn it up please help me
Hmmm
How long was the power off?
What type of heating? Hot water? Steam?
Do you have Radiators? Or radiant Heat?
Was 69 comfortable before, and always your t stat setting?0 -
And an obvious question...
is the boiler running? Does it run if you turn up the thermostat?
If not, what was the power problem? Is there a manual reset required on the boiler? Did it lock out for some reason (if oil, did the burner lose prime, for instance?). Was there a surge along with the power outage? If there was, did it fry something?Br. Jamie, osb
- 52 Job Opportunities
