To get email notification when someone adds to a thread you're following, click on the star in the thread's header and it will turn yellow; click again to turn it off. To edit your profile, click on the gear.
The Wall has a powerful search engine that will go all the way back to 2002. Use "quotation marks" around multiple-word searches. RIGHT-CLICK on the results and choose Open Link In New Window so you'll be able to get back to your results. Happy searching!
In fairness to all, we don't discuss pricing on the Wall. Thanks for your cooperation.
underfloor heating in a multi-family building
I have a an 8 floor, 8 apartment building with underfloor heating. It has central pumps, and no circulator pumps on the individual manifolds (two per apartment). The system is three years old and my super and I performed a system startup for the season. It has never been PM'd. The water was like mud and flow is low.
Question: Is water treatment recommended for these systems, and, is local pumping recommended? We are ready to perform some flow testing as we have had complaints that the residents "don't feel the heat"...we run 160F water (which seems high to me). Any experts out there that can help me?
  • SWEISWEI Member Posts: 7,356
    Where are you located?
    sounds like you could really use a proper system evaluation.
  • RichRich Member Posts: 2,129
    What
    tubing was used for the in floor panels ?   Any chance of you allowing us to view the near boiler piping and pumping arrangement ?  And as above where are you located ?
    You didn't get what you didn't pay for and it will never be what you thought it would .
    Langans Plumbing & Heating LLC 732-751-1560
    Serving most of New Jersey , Eastern Pa .
    Consultation , Design & Installation
    Rich McGrath 732-581-3833
  • WeezboWeezbo Member Posts: 6,232
    do the tests.
    keep the info.
    Flush the boiler. flush the system.
    take apart the end suction pumps and clean them check impellers for mud and clean them.
    flush the flow ports check the system again.
    you may have leaks that are causing 0 to infiltrate thru them or air elimination "Bleeders" or non barrier pex or an entrained air source that has successfully worn your impeller off the pump/s.
    piping dirt separator/s might help After you do the work and make the corrections . there may be steep learning curve involved in some of these things.
    hope that helps where to go with your time and efforts.
Welcome
It looks like you're new here. If you want to get involved, click one of these buttons!
