It's that time again!
ChrisJ
Member Posts: 15,709
Looks like I will finally get to fire the boiler up tonight.
Anyone else stoked about the heating season coming back?
Single pipe quasi-vapor system. Typical operating pressure 0.14 - 0.43 oz. EcoSteam ES-20 Advanced Control for Residential Steam boilers. Rectorseal Steamaster water treatment
boiler
Working in San Fran for 20 yrs I remember that part of September and October were the only months you could shut down boilers for more than a week. In July 2011 it never got above 60 degrees the whole month. But starting my career in Denver yrs ago I know what you mean, I always loved the smell of an old boiler room when firing up the boiler in the fall.There was an error rendering this rich post.
Let's not rush things!
Jeez, guys. I'm still trying to finalize the piping with Slantfin and convince a friend of a friend he needs to move up the date to go in business for himself, and start with MY install. He's a total pro, but no moonlighting. The other installer doesn't seem to know much more than i do, when all was said and done. I still have two good pipe fitters, but need someone to take all the elements and put it together. Not a DIY job, but I've sometimes felt it turning out to be one!!!Two-pipe Trane vaporvacuum system; 1466 edr
Twinned, staged Slantfin TR50s piped into 4" header with Riello G400 burners; 240K lead, 200K lag Btus. Controlled by Taco Relay and Honeywell RTH6580WF0 -
Woohoo!
Windows open...64 degrees overnight! Can't wait for October.0 -
Just turned
Cedric on for the winter. Supposed to be in the 30s tonight... but I like fall anyway!Br. Jamie, osb
Names
You named your boiler Cedric?
I guess I could call mine "Mr McClain" but I would have to use a German accent.
Joe, it's supposed to get down to 37F here in NW NJ tonight. Its already 48F so my windows are closed.Single pipe quasi-vapor system. Typical operating pressure 0.14 - 0.43 oz. EcoSteam ES-20 Advanced Control for Residential Steam boilers. Rectorseal Steamaster water treatment0 -
Fall and Winter ? YES!
I have to admit that I am looking forward to firing the new baby up again. I still need to drain it down and flush it out with a wand. When I refill it I will run it about 30 minutes after steaming begins, but I'm waiting for a spell of really cool weather to do that.
We have been down in the 40s several nights here in the QC, but due to the amount of extremely hot weather we had before the temperature finally dropped, The building is still warm, about 72 throughout.Dave in Quad Cities, America
http://grandviewdavenport.com0
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
