Indirect water heater and control
JTM
Member Posts: 1
I have a peerless boiler with an internal coil that provides hot water. I have hard water (12 – 13 grains of hardness, 204-221 ppm) and the coil calcifies every 4 years or so (at $800 a pop). The local heating company is recommending an indirect water heater to solve the problem. A couple of questions:
1) Will this truly solve the problem -- or is there a better solution? Will I still get calcification within the indirect system itself and/or piping?
2) They are recommending the Buderus S32 (S120) and the Crown Megastor 40 at over $400 more -- are both capable units? is the Megastor worth $400 more?
3) Should I replace my older control box with a "cold start" model ($330 more) or a Beckett Aquastart ($398 more)?
Thanks so much
Thanks so much
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
