Low water cutoff's
KBP&H_3
Member Posts: 67
Why don't low water cutoff's also include a pressure side that would also need boiler pressure to continue working.?
That would be
a pressure switch which is usually a separate device.
Personally, I don't like combination devices.8.33 lbs./gal. x 60 min./hr. x 20°ΔT = 10,000 BTU's/hour
Two btu per sq ft for degree difference for a slab0
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 848 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
