Firebox temperature in residential natural gas powered steam boiler
RobLC
Member Posts: 93
Would anyone know approximately how many degrees the boiler's firebox walls can reach?
Have been using Insulstick refractory mortar and it works pretty good but it's only good to just over 2000 degrees.
Would like a refractory, waterproof, mortar that can withstand 3000 degrees if that temp can be reached in a residential steam boiler. The minimum input for the burner is 400,000 btus.
Thanks for your help.
refractory
I have always used greenpatch -421 on commercial jobs 3200 degreesThere was an error rendering this rich post.
Greenpatch - 421
Thank you for this info. 3200 is a good number.0
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
