E.D.R. of convector
ben_18
ben_18 Member Posts: 70
I am trying to figure out if the boiler is the right size for the house. There are a couple of convectors in the system. They are like the ones found on page 101 in "We've got steam heat." What is the E.D.R. per inch of these convectors?
  • DanHolohan
    DanHolohan Member, Moderator, Administrator Posts: 16,653
    That's a generic picture
    Lots of manufacturers made convectors that looked like that and the rating would depend on which one you have. Pictures would help.
    Retired and loving it.
  • ben_18
    Heres the picture
    The convectors are built into the wall and can't be opened up. I guess the height of it could be measured buy putting a tape measure in through the top and bottom if that would help. Attached is a picture of it.
  • DanHolohan
    Ouch.
    These always shrug their muscles and give one the hairy eyeball. Without knowing what sort of element is hiding back there it's just guessing.
    Anyone else want to wade in here?
  • Danny Scully
    Danny Scully Member Posts: 1,462
    edited May 2013
    Can we?
    Can we consider that a hidden radiator Dan?! Hehe, that grill looks like it can be removed. Similarly, the opening at the floor seems somewhat accessible. I would remove the grill, measure the length/depth of element, then probe from the bottom and top to see if you can get an idea of the height. I would do this on 1 radiator and use as a template, so to speak, for the rest.
  • DanHolohan
    You would, Danny.
    But I don't know our guest's abilities when it comes to probing into walls. A lot went into the design of those things.
  • DanHolohan
    You would, Danny.
  • ben_18
    I would take
    the cover off but it is covered by sheet rock and I don't want to ruin the paint.
    I guess the bottom could be taken off. I have taken off the cover and looked inside. Here's a picture-
    Steamhead Member Posts: 17,947
    Here are two sources
    which you can find right here in the Library. Yes, it really does pay to wander off the Wall:
    http://www.heatinghelp.com/article/158/Radiators/1269/Herman-Nelson-Invisible-Radiators
    http://www.heatinghelp.com/article/158/Radiators/1280/Trane-Heat-Cabinets
    Now, how did I know these could be found there?  ;-)
    Consulting
  • ben_18
    Looks good
    Thanks! I have my work cut out for me.
  • SWEI
    SWEI Member Posts: 7,348
    While you're at it
    See if you can slip a vacuum hose down there and clean those fins.
