Check valve position
hrlevy
Member Posts: 19
I am installing a laundry tub pump for washing machine to drain into. I was wondering if the check valve can be installed horizontally or does it need to put vertically. All the instructions say is to install near to pump.
thank you.
thank you.
check valve
on a 45 degree is best0 -
but if you can't do that
a regular swing check should -- in my view -- always be installed so that the flow through it is horizontal or upwards -- never downwards.Br. Jamie, osb
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 60 Pipe Deterioration
- 848 Plumbing
- 5.8K Radiant Heating
- 372 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 39 Industry Classes
- 15 Recall Announcements
