Does anyone make a mini-split with 8 indoor units and 1 each 4-ton heat pump unit, 3-phase?
Howard_7
Member Posts: 11
Does anyone make a mini-split with 8 indoor units and 1 each 4-ton heat pump unit, 3-phase? Thanks!
Not Sure?
I'm not sure that I fully understand you question. You might check out Mitsubishi City Multi though.
Rob0 -
fujitsu
google fujitsu generalThere was an error rendering this rich post.
mini split
check the mitusbishi city multi i don't think that it will go down to 4 ton, in the
460 volt 3 phase. i believe the smallest is 6 ton. or is your voltage 208/230 3 phase0 -
mini split
the mitusubishi city multi that i looked at are the R-2 series and the Y series
the H2i Y series also the S series but it is not 3 phase that i could check0
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 848 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 27 Recall Announcements
