What are the flow rates coming out of this Tee?
Eastman
Eastman Posts: 1,002
If flow z = 6gpm, what does x and y equal?
flow x = ?
flow y = ?
The 3/4 inch side loops are equal in every way. (length, elbows, etc...)
Yes, the question is as simple as it seems.
  • CMadatMe
    CMadatMe Posts: 3,086
    Ummm...
    Forgot to study last night....Hmmm. It's coming to me....Let me think.... 3!
  • Eastman
    I need some else though
    I need more than one opinion.
  • unclejohn
    unclejohn Posts: 1,833
    I belive the ole
    What goes into a tee must come out rule applies here. So 3.
  • flow rate
    since both loops [x,y] are equal, then the flow must be the same in each.
    due to the incompressibility of water, then the flow will be 3gallons in each.--nbc
  • Eastman
    That should be good.
  • ced48
    ced48 Posts: 469
    Yes, 3!
    Don't get flow rate confused with velocity.
