What are the flow rates coming out of this Tee?
Eastman
Member Posts: 927
If flow z = 6gpm, what does x and y equal?
flow x = ?
flow y = ?
The 3/4 inch side loops are equal in every way. (length, elbows, etc...)
Yes, the question is as simple as it seems.
flow x = ?
flow y = ?
Ummm...
Forgot to study last night....Hmmm. It's coming to me....Let me think.... 3!"The bitter taste of a poor installation remains much longer than the sweet taste of the lowest price."0 -
I need some else though
I need more than one opinion.0 -
I belive the ole
What goes into a tee must come out rule applies here. So 3.0 -
flow rate
since both loops [x,y] are equal, then the flow must be the same in each.
due to the incompressibility of water, then the flow will be 3gallons in each.--nbc0 -
Thanks
That should be good.0 -
Yes, 3!
Don't get flow rate confused with velocity.0
- 85.2K THE MAIN WALL
- 55 Biomass
- 73 Chimneys & Flues
- 130 Geothermal
- 3.3K Oil Heating
- 61 Pipe Deterioration
- 885 Plumbing
- 5.9K Radiant Heating
- 376 Solar
- 14.7K Strictly Steam
- 59 Water Quality
- 49 Industry Classes
- 89 Job Opportunities
- 28 Recall Announcements
