Main Vent Spitting out Water
ALIGA
Member Posts: 194
Few weeks back new steam boiler installed.
Noticed a few things, and now it makes sense:
- loosing water from boiler
- hearing alot of air coming out of 3-4 radiators fed from this main
- alot of dirt in the sight glass.
Today I notice water coming out of one of the gortons, alot of water, the gorton is a few months old. could the main and return have dropped a bit? before the new boiler went in, I did not have this issue.
Can I jack up the main and return an inch? Thoughts and guidance are welcome. thank you all.
Repitching the main?
Check it with a level first. If you have to repitched it, what else will move if you jack it up?
I suspect your pigtail, or pressuretrol is allowing the pressure to get too high. An accurate 0-3 psi gauge would tell you when the pressure gets out of control.
Was the boiler cleaned after installation? Do a search for skimming.--NBC0 -
Main repitch
Hi NBC, i have a 5 psi guage, and the boiler shuts off around 1.5 - 1.7 psi.
I skimmed it on Sunday.
From the piping pic, can you tell if it is a parallel or counterflow system?
Shouldnt the excess water go back to the boiler via the lower return?0 -
Looks like it is a parallel system
I jacked the end of the main/return a little less than 1/4 inch.
Water stopped spewing out the vent.
Return has a slight pitch back to boiler. Main has a slight pitch away from boiler.
Hopefully this does the trick.0 -
Glad to Hear It's Working Better
I'd re-insulate that main so it's not generating so much condensate.All Steamed Up, Inc.
https://heatinghelp.com/find-a-contractor/detail/all-steamed-up-inc0
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
