To get email notification when someone adds to a thread you're following, click on the star in the thread's header and it will turn yellow; click again to turn it off. To edit your profile, click on the gear.
The Wall has a powerful search engine that will go all the way back to 2002. Use "quotation marks" around multiple-word searches. RIGHT-CLICK on the results and choose Open Link In New Window so you'll be able to get back to your results. Happy searching!
In fairness to all, we don't discuss pricing on the Wall. Thanks for your cooperation.
electric duct heater
Hey everyone I'm on a job in NYC and I see a electric duct heater in a duct that is pulling outside air...can anyone tell me WHY there is a duct heater in here? Just would like to know
ASM Mechanical Company
Located in Staten Island NY
347-692-4777
[email protected]
ASMHVACNYC.COM
  • unclejohnunclejohn Member Posts: 858
    To temper
    The air going into the building.
  • Eugene SilbersteinEugene Silberstein Member Posts: 349
    Freeze Protection
    Very often, heaters are used on fresh air ducts to prevent the freezing of hydronic heating coils. This is common on systems that operate with 100% outside air.
    Eugene
  • EmpireEmpire Member Posts: 2,343
    Hi Eugene;
    While I do not classify it as freeze protection, I find (depending on the installation and it's application) It is usually slammed in when a restaurant finds out that the doors are impossible to open, pilots on oven equipment keep going out, etc...  Outside air must be heated so the dang thing does not freeze out patrons and their space is having problems so in turn the duct heater is put in.
    Now, I'm not crazy Eugene....lol.  If this were a MUA equipment, then that heat is intended and sized for a specific application which may encompass exhaust fans and F/A make up to apply positive pressure to the space or structure.  I think what he is seeing is a heater retro fitted to help out a problem and that was probably the cheapest answer to alleviate the problem.  Yes, I know what you were inferring to and understand.  I usually think commercial kitchen because I run into it all the time.  Wow, I do sound crazy....lol  How have you been Eugene?
    Peace
    Mike T.
    Very likely
    You are indeed correct.
    I have seen them installed as a quick fix for problems such as those you mentioned.
    Eugene
Welcome
It looks like you're new here. If you want to get involved, click one of these buttons!
