For conversion from oil to gas, power burner or tankless
poconodc
Member Posts: 1
in Gas Heating
Tim,
In converting from oil, getting conflicting advice on whether to replace 1995 EFM Spk 600 with a new nat gas power burner, or opt for new tankless hi efficiencey unit. Present EFM has tankless coil for DHW and 142,000 BTu/hr output at 1.35 gal/hr, which I guess is about 190,000 Btu/hr input. House is about 1600 sf ranch with lots of baseboard cast iron radiation, well built and insulated.
I presently use about 750 gal of oil/yr here in Stroudsburg, Pa and also burn several cords of wood in a fireplace insert. Am set up for nat gas, and will be in house for 5 more years. Chimney has good SS liner, have large basement, and can easily vent outside. It is a long run from furnace to bathroom.
Large local outfit whis does many conversions suggest tankless; long time HVAC contractor says go with power burner and indirect.
What do you think?
What do you think?
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 848 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
