crown,new yorker,slant finn
Hi my supply house has these three oil fired boilers in stock.home owners budget cant go for a burnham.i hear crown makes a good boiler.im not very familiar with oil boilers but of the three which would be the best.heat loss was done and correct size boilers are available.thanks
  • CMadatMe
    CMadatMe Posts: 3,086
    Crown
    Is owned by Burnham Holdings. The AWR is the same cast as the Series 2, 3, ESC and ES2. The FWZ is the Burnham MPO Block and the TWZ I believe is the V8 block as the Burnham foundry is now pouring their iron for them. So if you like Bunrham it is the same product in a different jacket with a little control difference in some boilers.
    Stock both Crown and Burnham..
  • jonny88
    jonny88 Posts: 1,139
    thanks
    when you say stock both crown and burnham does that mean you have a supply house and if so where.i will travel as i am having problems getting controls etc on long island.thanks
  • CMadatMe
    Hicksville
    Yes, we have a branch in Hicksville and I just happen to be there today..I have 3 and 4 section Crown with and less coil in stock as well as gas boilers.
    Universal Supply
    120 New South Road
    516-348-7750
  • crown,new yorker...etc...
    like  crown...have put  in  quite a few...customers  happy....good boiler for the money...
