Boiler stand for TT boiler
bob eck
Member Posts: 930
Hi I am looking for a boiler stand for a Triangle Tube Challenger Combi boiler. I know Triangle Tube offers one just checking to see if there is one made that is priced a little more competitive than the one TT offers.
www.phpinc.us
I think still builds standsBob "hot rod" Rohr
Living the hydronic dream0 -
Has anyone?
Has anyone tried running unistrut from floor to ceiling? I would think 2 struts would be stiff enough. The top and bottom would obviously have to be anchored to concrete or framing. The hanging bracket would be better if it were through bolted, so it can't slip."If you can't explain it simply, you don't understand it well enough"
Albert Einstein0 -
this stuff is great
http://www.8020.net/
give them a design and they will build it or buy material and you do it. really works well.0 -
We usually build a wall
Shoot a plate down and screw one in overhead with a few vertical studs,1/2 inch ply and a couple coats of grey floor paint.
Gets you started with a flat level surface that you can screw your bell hangers and split ring stands to.
Also is nice to hide your wires behind and mount pumps.0
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
