Recessed radiators
Reno7211
Member Posts: 2
<strong>I have a customer who wants to remove her free standing cast iron radiators and go to the recessed type. This would require breaking into the wall and placing the radiator against the exterior wall. I was thinking of using foam board with a metal sheeting for insulation. Any thoughts on how well the new rads would work?</strong>
John Seigenthaler
John Seigenthaler has done tons of math and experimenting with wall panels. His book Radiant Precision has all the info you need."If you can't explain it simply, you don't understand it well enough"
Albert Einstein0 -
is this what
you're talking about? If so, you have to allow plenty of space below and above the radiator for proper convection.
As far as insulation, the higher the R-value, the better.8.33 lbs./gal. x 60 min./hr. x 20°ΔT = 10,000 BTU's/hour
Two btu per sq ft for degree difference for a slab0
- 85.7K THE MAIN WALL
- 51 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 60 Pipe Deterioration
- 850 Plumbing
- 5.8K Radiant Heating
- 375 Solar
- 14.5K Strictly Steam
- 51 Water Quality
- 38 Industry Classes
- 55 Job Opportunities
