Latest from Rinnai
Tim McElwain
Member Posts: 4,625
They are now using InnoFlue which is produced by Centrotherm EcoSystem a polypropylene material.
<span style="font-size:24pt"><span style="color:#000000">Rinnai Introduces Two </span></span><span style="font-size:24pt"><span style="color:#000000"></span></span><span style="font-size:24pt"><span style="color:#000000">Condensing Product Accessories </span></span><span style="font-size:24pt"></span><span style="font-size:24pt"><span style="color:#000000">at 2012 AHR Expo</span></span><span style="font-size:24pt"></span><span style="color:#000000">Company launches condensate neutralizer and dual pipe venting option for added installation ease</span>
<span style="font-size:12pt"><em> (PEACHTREE CITY, Ga. – Jan. 23, 2012)</em> Rinnai Corporation, manufacturer of the No.1 selling tankless water heater brand in North America, is launching two accessories to enhance its condensing product lines at this year’s Air-Conditioning, Heating, Refrigeration Exposition (AHR Expo). The company’s new condensate neutralizer accessory removes acidity from the condensation that is produced by a condensing tankless water heater or boiler, ensuring that it has a neutral pH level in accordance with select state requirements. Rinnai is also introducing a dual pipe venting system for its condensing tankless water heaters that utilizes a 3-inch polypropylene pipe to provide installers and homeowners with increased placement flexibility and installation options.</span>
<span style="font-size:12pt">“At Rinnai, we’re constantly working to identify new products and programs that simplify the sale and installation of our water heating and home heating units,” said Rinnai Vice President of Marketing Brad Sweet. “We brought the condensate neutralizer and dual venting option to market specifically to address the needs of installers that work with Rinnai’s condensing technology. The addition of these accessories helps to round out our portfolio of solutions for installers while ensuring the smoothest installation possible.”</span>
<strong><span style="font-size:12pt">CONDENSATE NEUTRALIZER </span></strong>
<span style="font-size:12pt">Rinnai’s new condensate neutralizer accessory provides installers with an effective way to eliminate acidity from the condensation that is drained from a condensing boiler or condensing tankless unit. The company introduced the easy-to-install feature because select states require condensate from condensing appliances to be treated before passing into a public sewer system. Rinnai’s condensate neutralizer works by running the condensation through a container filled with limestone media, which raises its pH level to make the liquid less acidic, resulting in neutral water that can be drained directly from the unit. Designed for both vertical and horizontal mounting, the condensate neutralizer’s user-friendly clear capsule design allows homeowners to see when the limestone media needs to be replaced. Additional limestone can be purchased from a Rinnai installer.</span>
<span style="font-size:12pt">“The condensate neutralizer is quickly becoming an essential component of condensing product installations in many markets,” said Rinnai Product Management Specialist Tracy Young. “Because we expect the number of states requiring the neutralization of condensate to grow, Rinnai proactively introduced this solution to make acidity a non-issue for our condensing units.”</span>
<strong><span style="font-size:12pt">DUAL PIPE VENTING OPTION</span></strong>
<span style="font-size:12pt">Rinnai is also introducing a dual pipe venting option for its condensing tankless water heaters. The new system, which connects to Rinnai’s standard concentric vent via a concentric twin pipe adaptor, enables a greater variety of installation options by accommodating venting in tight spaces, such as between a ceiling and subfloor, and making raised terminations easier and less expensive. Each pipe is 3 inches in diameter, so the system is ideal for long vent runs, and because it allows for greater distance between the intake and exhaust terminations, the potential for condensation from the unit to freeze over the intake in very cold climates is virtually eliminated.</span>
<span style="font-size:12pt">The new system’s exhaust pipe venting is a product called InnoFlue®, which is produced by Centrotherm EcoSystem and is made of the same polypropylene material that is found in Rinnai’s condensing concentric venting. With a maximum temperature rating of 230° F, polypropylene is specifically engineered and certified for use with condensing tankless water heaters. The new InnoFlue® venting offers the zero clearance to combustibles benefit of Rinnai’s standard concentric venting, a 10-year warranty, and positive fit and lock for secure joints without cementing or curing. In addition, InnoFlue® venting is 100% recyclable and earns points toward Leadership in Energy and Environmental Design® (LEED) certification because it does not use solvent-based primers and adhesives.</span>
<span style="font-size:12pt">“Rinnai’s dual pipe venting system addresses many common installation complications and enables more homeowners to enjoy the benefits of our condensing tankless water heaters,” said Rinnai Global Product Manager Trey Hoffman. “By making condensing tankless technology available to a wider array of homes, we believe the dual pipe venting system will help expand our installers’ customer base.”</span>
<span style="font-size:12pt">For more information on Rinnai, visit </span><a href="http://www.rinnai.us/">[u][size=12][color=#0000ff]rinnai.us[/size][/color][/u]</a><span style="font-size:12pt">.</span>
<strong><span style="font-size:12pt">About Rinnai </span></strong>
<span style="font-size:12pt">Rinnai America Corporation, a subsidiary of Rinnai Corporation in Nagoya, Japan, was established in 1974 and is headquartered in Peachtree City, Ga. Rinnai Corporation manufactures gas appliances including tankless water heaters, a wide range of kitchen appliances and heating and air conditioning units. As the technology leader in its industry, Rinnai is the largest gas appliance manufacturer in Japan and is the No. 1 selling brand of tankless gas water heaters in North America. Annual corporate revenues, including those of its subsidiaries, are in excess of $2.5 billion. With a global perspective to create 21st century products for the home and business, Rinnai Corporation commits itself to safety and the pursuit of comfortable lifestyles. For more information about Rinnai and their entire product line, visit </span><a href="http://www.rinnai.us/">[u][size=12][color=#0000ff]rinnai.us[/size][/color][/u]</a><span style="font-size:12pt">.</span>
<span style="color:#000000">More Information</span>
<span style="font-size:12pt">Katie O’Neill
three
(404) 835-4527
</span><span style="color:#0000ff">koneill@3atlanta.com</span>
<span style="font-size:12pt">Suzy Bowen
three
(404) 835-4529
</span><span style="color:#0000ff">sbowen@3atlanta.com</span>
<span style="font-size:12pt"> </span>
three
(404) 835-4527
three
(404) 835-4529
Actually, Tim
They have been using the poly-prop since the introduction of their condensing models and boilers. It is the 3/5" concentric. When Rinnai Japan (RJ) was designing the condensing units we told them we need a PVC vent. RJ Engineering took one look at the PVC and said no way! Emphatically I might add. We wanted it for competitive purposes. They wouldn't allow it for liability purposes. It is not approved venting material! Rinnai took the high road on this issue and I think it has hurt them in the market, but they are correct! The poly-prop is clearly superior, safer and IS a vent system.0 -
I posted this article
to clear up some confusion about correct factory authorized venting on Rinnai units. It seems I still keep seeing PVC and CPVC which I tell contractors based on Rinnai (manufacturer) is incorrect for their package and is technically a code violation. One I saw was actually in a mechanical inspectors house! I was told that it was correct as Rinnai had tested and approved their units for PVC/CPVC, I simply asked to see the test results. This unit was also dumping condensate into a sump hole with out being neutralized. Don't do as I do do as I say I guess is the inspectors take on things.0
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 848 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
