Internet Controlled Tstat for Steam heat
Annie
Member Posts: 9
I was looking at the Prophilix models. Can you suggest any others that can be controlled remotely? We have replaced Tstats before, would the only difference be the hookup to the Linksys?
internet control
what would be the purpose of this remote control? is this a house with only occcasional use [week-ends]? setbacks do not usually result in a savings in fuel cost, unless for several days.--nbc0 -
We plan on moving out of state but renting out the unit. We have 4 units and the one we are in controls the temp for the other 3 as well. We would like access to it without having to travel.0 -
thermostat under long distance controll
it is important that any thermostat chosen be "steam adaptable". most people here like the honeywell visionpro, which although not internet capable can be set to use a password, i believe. it can also use a remote sensor, with the main unit under lock and key.
i presume that you want to cut down on the occupants fiddling with the settings. if the system is well maintained, then the lowest cost of operation is had by maintaining a constant temperature. the remote sensor could be in the coldest room, with the control in a basement locked room, with the temperature set to maybe 66 degrees.
you could also search the tekmar site, and see if there is anything there, which is internet, and steam capable.--nbc0
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
