Oil tank guage
RyanC
Member Posts: 38
in Oil Heating
The gauge on my tank appears to be stuck. I'm assuming it's stuck since it's been a month since my last oil delivery and it is still reading 7/8ths full. Is replacing the gauge something I should try?
Thanks,
Ryan
Thanks,
Ryan
Not a big deal
Check the old one you maybe able to fix it, if not : Remove the vial hold the bobber and make sure the arrow is not pointing towars the fill or oil lines if top feed.0 -
Not a bobber type
The one that is there is not a bobber type. It is more like a dial. Does that make any difference?0 -
Tap gauge face with your knuckle--worth a try
HO here, that worked for me with my Roth tank months back. the guess from techs was that fill went slightly past the recommended max, and some foam temporarily gummed the works. Company offered to replace the gauge, but on a hunch i tapped it and it went back up. (In my case it was stuck lower than should have been, leading me to think delivery amount was less than receipt said.) It's been fine since.
Note that on a 275 gal roth tank max fill is 263gal and recommended max fill is about 240gal; so I've been told by techs who should know.0 -
What?
What kind of tank do you have? Is it a Roth? If so you will need to get the same gauge as you have now. If you have a standard type 275 you could get the same gauge type or get the bobber type as I described.0 -
Tank type
I have no idea what type/brand of tank it is. I dont see anything on it that would tell me. Is there anything I should be looking for?0
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
