Danfoss Zone Control Panel
Member Posts: 4,011
This is an old installation; 6 years ago when Danfoss built pre-plumbed panels. In this particular one, they used a Heat Timer DRC outdoor reset control that powered a Danfoss ABNV head on a mixing valve. Unfortunately, this control does not work anymore (it does not send an "output" to open the valve) and Heat Timer no longer makes them and they don't make a replacement; best they have is a variable speed pump control, so I'd have to re-pipe it.
Anyone know of a control I can simply switch with the DRC? tekmar? Taco?
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
