When will people learn,
that they make <em>bronze circulators </em>for a reason.
This was on an A/H supplied by a DWH.
When....
Cast iron cost less than bronze :-)
The general thought process in the field is, "The water mains in the street are cast iron, so it must be OK to use cast iron pumps..."
The other thought process is, "Heck, if it last for 5 years, I can AFFORD to replace it every 5 years, and still be $ ahead"
You, I and others know differently, but that's what people in the field think.
Education is our first most important job.
Keep up the good work Dave.
METhere was an error rendering this rich post.
Fine thinking!!
You are all missing the point! JOB SECURITY!! If you install a cast pump then you get to charge for more often system cleanings, replacing pumps.......
Unless you're one of those weird people that have the opinion of "do it right the first time" What a concept
Too bad common sense isn't very common!There was an error rendering this rich post.
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
