PEX in Gravity?
ever patch in a gravity system with pex? We have a couple risers in the way of a new medicine cabinet and it sure would be easier to use pex than elbow our way around it. The system IS hooked up to a new Prestige so there is some forced circulation. Any thoughts?
If you're
using the Prestige pump, it's no longer a gravity system.
Keep the PEX sloping upward whenever possible; should work fine if you keep the length short. Try it out before you cover up.0 -
Hot water?
Seems that if the inside diameter was close, and proper support was present, I would think it would be fine. Oxygen barrier of course. Take into consideration the temp. ratings as compared to the system operation. PEX can be a wonderful thing! My 2 cents.
PeaceThere was an error rendering this rich post.
True on the pump, figured I'd toss the idea out there in case anyone has a good horror story to tell. ;-)0
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
