Leaky Pipe
bob young
Member Posts: 2,177
taking on excessive fresh water will destroy your boiler. have the leaks repaired asap.
Leaky Steam Pipe
I just noticed today that I have a leaky steam pipe in my crawl space. Explains why the auto water fill on the boiler runs almost everyday. It is a single pipe system.
What are the suggestions for repair? Do I replace pipe and/or elbow or first try some pipe sealer? It appears to be leaking at the elbow that turns up into the floor. Can it wait for warmer weather as other than the water puddling on the vaper barrier it does not appear to be doing any damage? Hard enough to get into the crawl space in warm weather. Am I loosing much efficiency?0
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
