Munchk service
Floyd_50
Member Posts: 8
I inherited a couple of these and they have not been serviced in the 6 or so years since they were installed...
Question is...do I need any gaskets, service kit, or any such things in my hands before I yank the burner and check out wear and tear, clean out crap, etc...
Also what should I be looking for as to potential future problems..
Thanks!!
Floyd
Thanks!!
Floyd
Munchkin service
I would take with me a Refractory,target wall,burner gasket,blower gaskets. Not to mention a spark electrode and a flame rectifier. If it is 6 years old it ptobably has the old blinker board. The 925 control upgrade is a great idea if they will spend the money.0 -
I had one a couple weeks ago that had not been service in years. it was pretty Nasty!! even the Combustion was dialed in.. I did not need any gaskets,.. but the rubber hose that connects to the Bottom of the chamber( Condensate drain) was deteriorated and in need of replacement.
I had ordered the kit before Tearing into this one..
I took the Hole chamber and soaked it with CLR and a brush and credit card in the slots and cleaned it in my tub..It is actually not a small job!! Hope this Helps.. Heatmeister..0
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 60 Pipe Deterioration
- 848 Plumbing
- 5.8K Radiant Heating
- 372 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 39 Industry Classes
- 15 Recall Announcements
