Vitotronic 200 and circulators
Dave_4
Member Posts: 1,405
Hello,
I recently had Vitola with indirect DHW tank installed. The control is a Vitotronic 200. Currently, the control is set to DHW production only. Because the heating circuits are off, I closed some hand valves on those circuits (I figured it prevented a bit of heat escaping even though there are check valves).
I was reading the documentation of the Vitotronic 200 the other night and I came across something interesting - it mentioned that even though the heating circuit is off, it will run the circulators once every 24 hours to ensure the circulators do not seize. Did I understand this correctly?
Since I closed the hand valves, I bet the circulators are not enjoying life when they get turned one once a day. Can this damage the circulator?
Thanks.
Thanks.
Off-Season Circulators
I cannot speak to the specifics of the Vitotronic, but off-season cycling of circulators, especially water-lubricated circulators is commonly done across a wide variety of control platforms. The idea is to prevent seizing of the rotors when they sit idle. Once per 24 hours sounds like a lot. Most I have seen run them for 3 minutes or so every 72 hours.
I would open the valves and let the circulators fully express their inner potential- to hold them back (dead-heading) is definitely not recommended. A short close off of a few seconds for testing is one thing but not longer and not a habit.
Cue theme from "Born Free" here."If you do not know the answer, say, "I do not know the answer", and you will be correct!"
-Ernie White, my Dad0
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
