Tapping Cast Iron
Adam Grant
Member Posts: 7
How difficult is it to tap plugs on a cast iron radiator?.What would be the best method?
TAPPING IRON
exact size quality brand new drill bit. oil. correct sharp tap. experience. practice on scrap iron or you might destroy your radiator. best of luck & TAKE YOUR TIME.0 -
Right on, and
use a hand drill or a power drill that is barely turning. This is where a steady hand is most important and speed truly destroys.0 -
couldn't agree more
sharp bit and tap, and drill slow. Good cast iron is soft and drills and taps easily. I have done it many times over the years. I usually use pro-poxy on the threads or Xpando just to be on the safe side0
- 87K THE MAIN WALL
- 116 Chimneys & Flues
- 107 Geothermal
- 983 Plumbing
- 389 Solar
